Thread: Any issues with loaded filter sock in pump skimmer basket???
    Apr 2017
    OC, California
    8
    Greetings all:
    Not sure if this is the right place to post this, so Mods, feel free to move if necessary...
    Anyway, I'm in the process of rebalancing after refilling my pool, so I need to get my CYA up. I'm not about to pay the cost of liquid CYA (around $38/gallon at the local pool store), so I've self-selected my way into a granular product.
    Since I'd like to get this glop dissolved (relatively) quickly, I'm wondering if I'll have any issues with putting a filter sock loaded with dry CYA granules in the skimmer basket of my Pentair Intelliflo VS pump, then running at low speed?
    Thanks in advance for any and all help!!!
    18,400 G Kidney Shaped IG PebbleTec pool w/600 gallon attached spa & associated overflow
    Pentair VS DC Pump; Pentair DE Filter, Jandy/Laars Heater, Hayward AquaRite 900 series SWG (new addition...)
    40,878
    Re: Any issues with loaded filter sock in pump skimmer basket???
    I would not recommend it as it might restrict the flow too much.
    You can get it to dissolve within a day if you hang it in a sock (or 2) in front of your return jet and massage it fairly often.
    Apr 2017
    OC, California
    8
    Fair enough. That's what I'll do. Thanks much for the quick response!!!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,309
    You can also set the basket in the pool skimmer basket, as long as it doesn't block the flow 100%. But leave the pump basket alone.
    40,878
    FYI, I use 2 large white athletic socks (almost like soccer socks), fill them both up the same amount, tie the tops together and hang them over my brush pole in front of the return jet.
    Apr 2017
    OC, California
    8
    I'm rockin' the knee-high stockings that I got at Wal-Mart for less than a buck a pair.....so far, so good!!!
