Thread: Pool Cover ID
    buddywiser's Avatar
    Morgantown, WV
    98
    Pool Cover ID
    Looks like my 20 year old pool cover is dissolving. Nothing on the cover or the bag tells me the brand. The Meyco, Loop Loc, etc all look the same to me online. Anybody want to take a guess?
    24000 Gal, 18x36 Vinyl
    Hayward Super Pump
    Jacuzzi Tri Clops Cartridge Filter
    Heat Siphon Heat Pump
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,837
    Re: Pool Cover ID
    20 years is a decent run
    Unfortunately, just like liners, most companies purchase their cover fabric from the same source, so I'm not certain the appearance alone will help you ID it.
    If, however, an owner preceding you bought it from a local pool outfitter, and if you ave any idea who built/managed the pool in its early days, there may be a record of the purchase at the stor associated with your address.
    I'd purchased a foreclosed home a few years ago and was able to find out a good bit of info this way about my pool's construction, age, accessory purchase, etc. In my case, some elements were more like "back in 2001 we used polymer panels, not steel, so yours will be..." Etc.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
