Thread: Skimmer butterfly gasket to wide to fit properly?
    Jul 2013
    Ottawa,ON, Canada
    23
    I bought an Olympic(Champlain plastics) above ground pool large mouth skimmer and it came with 2 butterfly gaskets in the box. The wrong instructions were packaged in the box(they were for a solar blanket) but I looked online and found these instructions which aren't 100% clear:
    PDF
    I tried to install the butterfly gasket the way it's supposed to be installed, so split the middle and fit it on the pool wall and have a gasket lip on the inside and on the outside of the pool wall for the skimmer and the faceplate to sit on but the gasket was too large, I was never able to get it to sit in the skimmer hole properly. There was some slack in the gasket since it was too large and the holes didn't line-up. So I ended putting a butterfly gasket inside the pool on the liner for the face plate to sit on and one on the outside on the pool wall for the skimmer to rest on. These gaskets are pretty thick so I don't think it's the right way but should I be ok this way? I got the screws through both gaskets and screwed the skimmer in as tight as I could. Could I have any problems? When I removed the old skimmer it only had a gasket on the outside, it didn't have a gasket behind the skimmer face plate.
    9000 gallons AG Hayward Sand filter and Hayward 1.5hp Turbo Injection pump. 23 year old pool on it's 3rd liner.
    Aquacheck test strip and TF-100 test kit. Kontiki 2 automatic pool cleaner. Pool is filled form town water supply.
    domct203's Avatar
    Jun 2015
    CT
    3,915
    Re: Skimmer butterfly gasket to wide to fit properly?
    I think your problem is not the gasket, but that the hole in the pool is too small.
    If the skimmer is not leaking around the pool wall, I would leave it alone.
    I'm very surprised that the original skimmer did not have a gasket on the inside.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Jul 2013
    Ottawa,ON, Canada
    23
    Quote Originally Posted by domct203 View Post
    Me too, considering a pool installer replaced the liner in the pool 2 years ago and re-use the same old skimmer.
