Thread: Here we go...TF-100 for first time pool owner/tester
    Apr 2017
    Pittsburgh,Pa
    16
    Overwhelmed....but ready to learn. Results will posted after I figure it all out.
    20K gallons, IG, Vynl, Filter (DE; Pentair FNS Plus Vertical Grid D.E)
    Pump (not variable), Build (June 2016), Test kit (strips,
    SWG (Pentair Intellicor), Heater (Pentair Mastertemp)
    Pentiar Autimation (Sceenlogic controls pool pump, SWG, Waterfalls)
    Dolpohin M500 Ribit Cleaner; Two natural stone waterfalls
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Here we go...TF-100 for first time pool owner/tester
    If any results seem weird, check out Pool School - Extended Test Kit Directions
    There's also videos demonstrating each test https://www.youtube.com/user/TF100TestKit/videos
    Apr 2017
    Pittsburgh,Pa
    16
    First teat using daily. Chlorine looks high(est), correct?
    I am going to try the weekly test now.
    30,946
    Bring up that weekly test results. To me, your ph looks around 8.0 with at least 5 ppm chlorine.
    Apr 2017
    Pittsburgh,Pa
    16
    I just posted the following in a new thread...
    First time using TF Test Kit
    Chlorine Test-Daily (goal 2 ppm)
    5/16 - 5 to 10 (simple test strip was "high" as well)
    Chlorine Test - Weekly:
    5/16
    FC = 8 (16 drops x .5)
    CC = 1 (2 drops x .5)
    TC = 9 (8 + 1)
    My salt dropped to 2800 due to lots of rain (I guess). I added two 40lbs of salt (one per day to learn the incremental increase) over the last two days. Salt is currently at 3200 per intellichlor (verified with salt test strip). Salt generator is set to 38%.
    Unsure what the next step is. Turn down salt generator and if so to what level?
    30,946
    Posting in a new thread was a mistake.....I have no idea where that thread is and cannot reply.
