Results 1 to 10 of 10
Thread: Opened Green Pool Bought test kit but still lost
    Jun 2016
    Mississauga
    5
    Bought the Taylor test kit
    Here are my levels
    CYA 30-35 ppm
    PH - so high couldn't register
    FC - 0
    Combined .4 PPM
    Alkalinity 70ppm
    Calcium 60ppm
    Pool guy that opened dumped one bottle of shock and Algaecide a few days ago and we have scrubbed walls and vacuumed. I have tried the pool calculator but confused, please help
    It is a saltwater pool and it is fibreglass. It is 11,339.85 gallons.
    Thank you
    2016 built Leisure Pool (carbon fiber reinforced fiberglass), Elegance 30 model, 12,000 gallon saltwater pool (42,926 litres) Hayward Ecostar Variable speed pump, Hayward Sand filter (with sorel mix) 250 BTU heater
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,299
    Re: Opened Green Pool Bought test kit but still lost
    Welcome!
    I'm not so thrilled there's algaecide in there. I hope it wasn't Copper-based. Forget it for now; it works best as a preventative not as a cure in the same way that wiping a surface with Lysol stops the spread of germs but drinking it won't cure a cold.
    Your test results aren't too bad, really. You don't have to drain and replace water. Be thankful for that.
    Step one: adjust pH. If you're reading above 8.2, it could be much higher. So plug the numbers into pool math and add the acid it calls for (pump on and left running) to get to 7.4 and let it mix for half an hour, then retest pH and TA. If it shifted, great. If not, try again. Eventually it will move. Just to be sure, you're comparing colors and the pH is at the top of the scale? You're not confusing the test with another and adding drops after the initial 5?
    Okay, so pH is 7.4 give or take. Now you grab the bleach. It will take a lot.
    Step-by-step instructions are in the SLAM article. Just follow it.
    If you need a little inspiration, check out Recovering my old inspirational links
    Jun 2016
    Mississauga
    5
    Thank you so much. So after adjusting the PH we can test again in about 30 minutes or do you think it would be best to wait for overnight? Yes, we are looking and reading the SLAM method. This is so new to us and like another language. I am sure we will be laughing at all of this by August but now this is like learning another language!
    Richard320's Avatar
    Jan 2010
    20,299
    Quote Originally Posted by charlotteash View Post
    If the pump is running and you make a few swipes with the brush to get things stirred up, 30 minutes is plenty. Remember that algae is growing as we type.
    And it won't be August. You'll be one of us before June. Once you start doing and seeing the test results change, it will all start to make sense.
    Jun 2016
    Mississauga
    5
    Sorry one more question. .once Ph is fine our pool is a salt water and our CYA level is at 30-35 ppm according to Slam it's not corresponding on the chart..so we don't know how much chlorine to shock with
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    236
    For now consider your pool a regular chlorine pool. You don't want any more CYA as it will only require more bleach. If your reading is 35 then call it 40, your slam level is 16ppm. When the water is cleaned up and looking good then you can raise the CYA and start the SWG.
    You need to get your FC chlorine up to there and hold it until 1: the water is clear, 2: Combined chlorine is .5 or less, and 3: you can pass the overnight chlorine loss test. Filter runs 24-7 and backwash or clean the filter when pressure rises by 25%.
    It may require testing and dosing a few times per hour in the beginning, as algae is killed the FC will begin to hold longer and you will be able to test less often. You will get a feel for how long.
    You must keep the FC at SLAM level, if the algae isn't being killed then it's coming back and it grows very fast.
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    Jun 2016
    Mississauga
    5
    Thanks very much, very helpful
    Dec 2016
    Arlington, Texas
    291
    You say you have the Taylor test kit, is it the K-2006? If so, use the acid demand test and then use the back of the Taylor kit booklet to know how much acid to add.
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Jun 2016
    Mississauga
    5
    Yes thank you we did that. Another question for all of you Slammers out there...how often to test the water once you slam? There are no specific timelimes on the website. We shocked at 1230pm..tested at 230pm..we are way above where we should be. We should be at 16 however we are at 24. Is there a guideline on how often to test while trying to maintain shock level? Thank you
    Jun 2014
    17,327
    Every pool is different. In the early stages of the SLAM, expect to test FC frequently - perhaps once an hour or so. If the FC is holding close to where you started, you'll see a pattern and can space it out. Conversely, if the FC takes a plunge, you know you need to test more frequently and add more bleach to maintain that FC. In time, the bleach will win over algae and you'll see a steady routine begin to take place. As for over-shooting the FC .. it happens. Just let it settle to your SLAM level and press-on. Good luck!
