Results 1 to 8 of 8
Thread: Pool drinking chlorine like crazy!
    So my new pool is clean, looks good, but I'm just wanting to ask...
    Should i be having to add half a jug of chlorine very few days? My fc seems to be getting close to 0 after about 2-3 days. Ph is 7.8-8.
    I've added some stabilizer; however I'm not a fan of the stuff, any better options?
    Pool is crystal clear, so there's that I guess
    Court from sunny FL!
    18X52 symphony abg metal pool
    blue torrent 2 speed 1 hp pump
    Taylor test kit k2006
    Apr 2013
    Sacramento, CA
    2,769
    Re: Pool drinking chlorine like crazy!
    Could you post some test results?
    Its most likely algae or not enough CYA, either of which is possible in Florida. So post some test results and we will take a look.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Sounds right.
    An 18' round pool filled 4' deep will hold about 7600 gallons. 1/2 jug of bleach adds 5.2 FC. If that lasts two days, that's pretty normal. If three days, that's really low consumption. It would be better not to let it drop below the minimum for your CYA, because if algae develops, you'd be amazed at how much bleach it will use then.
    Jan 2012
    'burbs of Augusta, Georgia
    8,556
    I wouldn't wait too long to add your routine doses of chlorine. I would suggest daily testing at first and always adding chlorine immediately if the testing shows your FC dropping below desired levels. You may find you're able to add chlorine every other day, but doubt any liquid chlorine is going to last much longer than that.
    How are you set up for a *good* test kit?
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    236
    Chlorine is a consumable, like gas in the car or food for the dog. What is consumed each day by the hot sun or by killing algae and bacteria must be added back. Most users here will add chlorine every day to maintain their required level. With a CYA level of about 40 you should keep about 4-7ppm of FC and never let it fall below 3.
    The best way is to test about the same time each evening and add the required dose to get back up to target range. The key is to add enough so that by the same time the next evening you are still above your minimum of 3. Just be aware a lot of swimmers in the pool will introduce extra bacteria to kill and will increase your chlorine demand. If you add a whole bunch of chlorine at once the extra above your stabilizer level, it just quickly burns away.
    You must have some stabilizer because without it, ALL your chlorine will rapidly burn away in the bright sun and warm water temps. A CYA level of about 40ppm is best for a pool subject to intense sun. The key is to not add too much. Tablets and granular shock get folks in trouble because they continually dose stabilizer into the water and it quickly builds up, gets too high and blocks the chlorine from working. Liquid chlorine bleach is the answer, it will not add anything but chlorine, water and a little bit of salt.
    Accurate test results, regular dosing and a few simple daily chores will have your pool beautiful, clean and safe for the entire summer. A few minutes to test, dose and clean the skimmer basket, it takes about 5 minutes. Add a few extra minutes on the weekend to brush the walls and floor and the pool just stays crystal clear. Ignore it or try to shortcut and the green monster will come out. You will sweat, scrub, test and buy cases of bleach to bring it back. It's much easier and more fun to just maintain it!!
    AGP 24' x 54" approx 14000 gal Full sun all day, Hayward 1.5 HP and EC50 D.E. filter
    Stenner 45MPHP10 10 gal/day fixed rate with intermatic ET1125C timer
    Dolphin E10 robotic cleaner, 330 gallon Tiger River Spa, Taylor K-2006C test kit
    triptyx's Avatar
    Apr 2016
    1,475
    Most important to what dsmith said, because it addresses your initial comments about not liking stabilizer, was having a correct and adequate level of stabilizer (CYA) in the pool. Too much is indeed a bad thing, but you need enough to help protect the chlorine from the sun. As long as you maintain a chlorine level that is appropriate for your CYA, you don't need to worry about having it in the pool.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    So just tested when I got home, we did pour chlorine and stabilizer in last night
    Results today
    Fc at least 10 if not more, still trying to get that figured out
    Ph 7.8
    Cya is around 60,
    dsmith99's Avatar
    Jun 2016
    SW, Iowa
    236
    Pool School - Chlorine / CYA Chart
    Stabilizer is a little high now, but still manageable. Use only bleach, no powder shock or tablets or it could become a problem.
    Look over the above chart, with your cya at 60 you need to maintain chlorine at 7-9 with 5ppm being your bare minimum.
    Start by testing each day, at 10ppm you are good for today, test tomorrow about the same time and see where you are. If the pool is 6-7ppm add enough chlorine to get back to 9ppm. If you test regularly, keep your chlorine above 5 at all times, brush the pool at least once per week you won't have much problem. It's very easy to test, dose, check the skimmer and clean the filter as required. Much more difficult to bring it back from green.
    If you have a lot of people using the pool it will increase chlorine consumption and it may need to add extra chlorine. Any time you are in doubt, run a FC test. Once you get CYA, TA, CH set you don't really need to test those every day. You should monitor FC, CC and PH each day, as you get familiar with your pool some folks are comfortable enough to cut back testing to every other day and just add the routine dose each day.
