Results 1 to 8 of 8
Thread: Best Cleaner Recommendation
    Oct 2016
    Tampa/FL
    20
    Burnt out reading threads. So, decided to post. My pool (see signature) is screened and pretty clean. If there are any leaves, their are just a few oak leaves someone tracked in (small). Oak bloom "balls" are a hassle because they fit through the screen mesh, then fIoat, then get stuck to the walls, then get waterlogged, then drop to the floor. I want to stay under $400 unless it's really justified. I'm not against a quality vacuum system either, I just don't want leaky cheap suction hoses or nuisance issues. I do have benches, steps and a sun deck, all adding rounded edges and crotches to maneuver.
    Let me have it. I'm not trying to be cheap but I think it may be worth a try at the less expensive options first.
    Thanks in advance for your input!
    Killer95Stang's Avatar
    Sunny SoCal
    697
    Re: Ugh-Best Vacuum Cleaner Recommendation
    I would ditch the suction side cleaner all together and get a refurbished Maytronics S 50, Active 10 or E 10 from poolpartz dot com. Your smaller screened in pool doesnt need much in a cleaner and mechanical suction or pressure side cleaners are like tube style tv's.... outdated!
    All three are under $400.00
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Oct 2016
    Tampa/FL
    20
    Thanks, I'll check it out!
    Oct 2016
    Tampa/FL
    20
    Re: Best Cleaner Recommendation
    There is no one at Poolpartz answering the phone. Not a good sign. Anyone else have an opinion?
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    Very quick shipment from them. Quite pleased with my refurb. I almost never try to talk to anyone when buying online. Just my approach. Worked well so far.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Oct 2007
    Parkland, FL
    753
    Quote Originally Posted by powergator View Post
    Email them, they responded very quickly to my questions and were very nice. I would have no issue buying from them, but usually you can find the same model for more but when you weigh the two year warranty versus one, to me its worth it to pay a little extra.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Call these people below. They sell a lot of high end cleaners, but they will give you an experienced un-biased opinion on the best cleaner for your budget, and they have lots of models. They are very knowledgeable and extremely helpful, and also seem to have some of the best prices, especially on parts.
    Pool Cleaners - Robotic | Marina Pool Spa & Patio
    Essential Links:
    I just bought an Active 30i from Marina. They have very good prices.
