Thread: sig test
    qpp1's Avatar
    Apr 2017
    Ville Platte, LA
    2
    sig test
    do I have a signature?
    7.6k gal, AG, .75 HP Intex pump, 120 lb sand filter, TAYLOR K-2006, Digital PH Meter
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: sig test
    Yep!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: sig test
    Indeed!
    And welcome aboard. Hope you post up if we can help, and enjoy the forum.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Re: sig test
    I see it, but there's a problem.... "water tested at local pool shop". Remember that their free testing is not done as a community service, but to sell chemicals.
    qpp1's Avatar
    Apr 2017
    Ville Platte, LA
    2
    Re: sig test
    ordered, Taylor K-1515 FAS-DPD chlorine test kit, and a Digital PH Meter
