Thread: Need New Equipment: Purchasing Housew/ 28k Gunite Pool with Diamond Brite and SWG
    Feb 2017
    Annapolis
    36
    All,
    I have been reading the forum for some time. I am about to close on a house w/ a 28k gallon gunite pool. The pool was built in 2007. The equipment is original. It has a Pentair Easy Touch control system w/ Intellichlor SWG. It also has a Pentair Quad DE 60 filter and a Pentair 1.5 HP pump (I cannot read model maybe WhisperFlo????). There is also an Aquacal Heat pump. Since the pool is not open we weren't able to test the system completely, but it appears the Easy Touch and Intellichlor are functional. The heat pump powers on but the system was not able to be fully tested.
    I will definitely need the following:
    1. Replacement pump for the Pentair WhisperFlo (1.5 hp)
    2. Replacement for the Pentair Quad DE 60 Filter (an FNS plus was recommended w/ multi port valve)
    3. 4x Jandy valves.
    4. Robotic pool cleaner
    Any advice on where to buy the equipment? Substitution recommendations? Installation recommendations? Pricing?
    Thanks for all the help so far!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    Re: Need New Equipment: Purchasing Housew/ 28k Gunite Pool with Diamond Brite and SWG
    R,
    If you have the EasyTouch, they are designed to control the 3 HP IntelliFlo variable speed pump. They are not designed to control the SuperFlo VS or any other VS pumps...
    I'm not sure about really old Easytouch systems, but I suggest you look to see if the IntelliFlo is on the Pump's menu...
    Push Menu twice.. once to wake it up, and two to get into the menu..
    Scroll down to "Settings"
    If you see "Clock" and below that "IntelliFlo" you'll know the unit is IntelliFlo compatible..
    Since this is a VS pump, it does not matter what HP the pump is..
    For reference, I can run this pump, 24/7, for less than $20 bucks per month.
    Post a couple of pics of your equipment and you will get more answers...
    Apr 2017
    Dallas, TX
    54
    I just rebuilt my Jandy valves. It's an easy job. I ordered new Jandy neverlube valves of the same size, and removed the doverters, lids and handles from the new valves and installed them in the existing valve bodies. Get the valves from Amazon for about $45 each
    just make sure you measure and get the right size new valves.
    Feb 2017
    Annapolis
    36
    Can anyone provide advice on what replacement equipment I should be looking at for 28k gallon pool? Any recommendations on places to purchase?
    Thank you!
