Thread: Chemicals
    Rodriguez559's Avatar
    Jan 2017
    Tulare/ca
    10
    Chemicals
    Ok guys interior finish about a week away and I'm going to maintain our pool which chemicals should I go get and always have on hand? Thanks for all your advice so far.
    In-ground freeform 32' x 21' Gunite, Sparkle quartz plaster, ePump 2.0, MX8 Elite cleaner
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Chemicals
    Just bleach and acid. The builder should get everything else set up for you, which means he'll add CYA. I've never ever had to add baking soda nor borax to my pool. Test results will tell you if and when anything needs to be added. You have ordered a proper test kit already, haven't you?
    Jan 2017
    Tulare/ca
    10
    Re: Chemicals
    Thank you, yes I went with the tf-100
    Apr 2017
    Phoenix
    500
    Re: Chemicals
    Glad you got your kit. No need to stockpile a bunch of chemicals ahead of time. Just wait for your kit and pool to be open. Once done, test it yourself and post numbers here and people will guide you.
    All you will ultimately need is bleach from your grocery store aisle. The regular unsented kind. It can be generic version as long as its plain old bleach. Bleach is also called liquid chlorine at pool stores or big box home improvement stores. Sometimes it's cheaper that route because they are higher concentrated. Bleach and liquid chlorine doesn't store long and degrades over time, so I would wait until pool is ready and then go get a few bottles to start.
    As for acid, it's called muriatic acid and lowers your ph. This can also be found at most big box stores and has different concentrations. This is the only item I do buy at a pool store because it's cheaper for the higher concentrated acid.
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
