Thread: Pentair MasterTemp Fireman Switch
    Sep 2016
    ND
    125
    My learning continues....I think that this is a pretty easy question for anyone that has this heater.
    If the heater has power, but the fireman's switch is open (no call for heat from the automation system), does the display panel light up, or does the display only illuminate when the fireman's switch is closed (calling for heat)?
    Derek - November 2016 Build, Fill, Cover, and Close. Starting Equipment for the first time in Spring 2017: 26K IG 20x40 Vinyl, All Pentair: IntelliFlo VST 2, Clean and Clear 420 Cartridge Filter, EasyTouch 8, IntelliChem, IntelliChlor IC60 SWG, MasterTemp 250K NG Heater, GloBrite LED lights, Autelis Automation Integration, CoverStar Leading Edge Automatic Cover, Dolphin Quantum Robotic Cleaner, Interfab G-Force 2 slide, Interfab T7 diving board
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    Re: Pentair MasterTemp Fireman Switch
    I only get lights on the panel when I'm heating. I've got an Easytouch panel that does the controlling. On when heat is needed otherwise no lights or direct control at the panel at all.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    ps0303's Avatar
    Jul 2011
    FL
    3,920
    When hooked into a control system like an Easytouch, if installed correctly, the heater does not power on the system board until the ET system tells it to.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Sep 2016
    ND
    125
    Perfect - exactly what I wanted to know. My gas line is buried but not connected yet (Tuesday is the plan). My IntelliChem and IntelliChlor are on the same relay as the heater. I pulled the connection for the heater from the back of the EasyTouch (to the heater's fireman's switch) hoping that it'll prevent the heater from turning on, and would still allow me to turn on the other equipment. Sounds like it'll work exactly as I'd like it to.
    Thanks!
    Just did a bunch of wire testing on the Mastertemp. The Heater has it own power wire at 115v. The fireman switch is basically a jumper wire that can be use as a switch. Its an open or close circuit depending if the jumper wire is there or not. Fireman switch operates at 24v.
    So if you use a jumper wire the heater will work manually with the heater control panel.
    If you wire the fireman switch's 2 wire to the easy touch Heater connector. The easytouch will open and close the circuit to switch the power on an off according to your temperature setting. You still need to manually set your heater to 104 degrees on the panel so the water can go up to that high for a spa. Easytouch will use the water temp sensor to dictate the heater on and off time.
    However if you want to keep the water below 80 for a pool. Manually set the heater temp to 80 and it will never to above that temperature. At this setting your spa will never get above 80 degree either. consider it a second level of water temp control.
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
