Thread: Buying a pump today
    Mar 2014
    Fort Worth, TX
    24
    Buying a pump today
    My pump sounds craazyy! no time to lose, gotta get something or risk hearing loss.
    Currently a Hayward Super 2 1.5hp Single Speed is there. Given that the pump is about 7-10 years old I figured I'd replace the whole pump. Should i replace it with a hayward Super 2 Dual Speed or something else (cheapest i found with switch was about $600)? Just looking for an Amen or someone to confirm I shouldn't get something else like a pentair intelliflow. Seems like the whole forum suggests dual speed on low for most people. Anything else to consider?
    24,000 gallon pool, DE Filter, 5 return jets, nothing else really
    25,000 Gallon Pool, In Ground, Plaster, DE Filter (need to get model), need to get pump, pool build year unknown
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: Buying a pump today
    Sounds like a plan.
    Before you lay out the long green, though, maybe pull the motor out of the pump housing. I once thought I needed bearings. Turned out a small piece of gravel got vacuumed up and made its way through the pump strainer and was caught behind the impeller. A couple gaskets is a lot cheaper than a motor.
    May 2009
    Youngsville NC
    395
    You can do the whole pump, or you can buy an equivalent 2 speed motor to replace what you have (if it is the motor). Buying a whole new pump does get you the advantage of a warranty. You can also consider dropping down to a 1 HP 2 speed pump as well - it would probably work just as well.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Mar 2014
    Fort Worth, TX
    24
    Hi Everyone,
    I just wanted to finalize this thread and let whomever may be interested know what I ended up doing. I bought a "Pentair SuperFlo Variable Speed Pump 342001". The 2 speed pumps didn't seem to be much less expensive than this VS one, and a variable speed presented more options such as:
    - I assumed that to get the right skimming pressure on low speed I may need to tune the pump speed
    - Don't have to run at max speed ever really. Can leave it at a lower max speed when adding chemicals, like 2700
    - The timer features are awesome. I've been leaving it running 24 hours a day at a low .. rpms? I set it to around 1200 which seems to be appropriate for daily movement, and around 2700 for when i add pool chemicals. I can probably adjust more as needed later
    One of the issues I had with Pentair was the 30 or 60 day warranty if not installed by a "professional", but my credit card has an "extended warranty" so I think if it actually messed up within 1-2 years it would be somewhat covered anyways. The installation was really easy too. It took a little bit of time, but it's just pipe and 3 electrical wires and a little bit of planning. There was also an awesome video on youtube about the installation of that specific pump
    Anyways, I wanted to thank the people that gave input and troublefree forums in general
    --Lee
