Results 1 to 8 of 8
Thread: New home construction ... considerations for adding pool
    Jun 2011
    Las Vegas, NV
    53
    My wife and I will be building a new home this winter and I wanted to check in here for recommendations to make it easier when we have our pool built. We live in Las Vegas and the last two homes we've lived in have had pools already built, so I will definitely be putting in a pool and spa.
    First thoughts: I want to make sure that there's a gas line installed near where our pool heater will end up. I am also thinking that (due to the extreme water hardness), we will want the pool to be refilled with soft water so we'll want a line for soft water that will be tapped for the pool. ... I know that the pool will initially need calcium hardness so my plan is to partially fill the pool with unsoftened water and mix in some softened water to keep the pool's CH level at reasonable levels. Once the pool's filled, any replacement water can be soft water so that the CH doesn't go up too much.
    That's all of the thoughts I've come up with so far - gas line + soft water for the pool.
    And of course, no stinkin' landscaping that will shed a bunch of debris, which invariably ends up in the pool.
    Any other considerations/ideas would be much appreciated. No rush; I don't expect to start pool construction until fall 2018. Home construction starts late 2017.
    Thanks in advance.
    Our pool is 15,000 gallons salt water new build. 16'x40' with spa. Pentair system with Screenlogic software, Pentair IC-40 salt cell, Pentair heater, Pentair filter. Bought brand new house in March 2018 and pool was built Apr-Aug 2018. And my favorite feature - an autocover we have floor jets to help keep the pool clean, but the autocover keeps the junk out so the floor jets just do minor cleanup.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Re: New home construction ... considerations for adding pool
    Exterior lights, plenty of outlets, preplan for speakers. This list may never end!
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,872
    Maybe consider a pool equipment room and a bathroom with access from the pool area.
    -Brian-
    Pool/Spa, Pentair Equipment
    Jun 2016
    NE/Pa
    1,494
    if u aren't finishing the landscaping for the area then i wouldn't worry about anything really except prep the foundation of the home for utilities out to pool area. i.e.: conduit for water lines, conduit for electrical lines, conduit for low volt (cat/audio ect) use 2 inch if you like overkill use 1 inch and u will be fine for 1 wire or line per conduit. the gas line will come off via ariser from the outside of the home gas meter vs coming from the inside of the house due to the fact that the reader for gas line is already outside vs water which is inside.
    i see no point bringing linesto areas if they might change cause then u r just digging them up again. you will have machine coming in and out so if you do finish yard a lot will be ruined again anyway so u can trench the stuff then.
    that's just me but i'm doing my pool now and the only thing i could have planned for that can't be done now would be the conduits. i'm going have to drill through my 12" inch poured foundation and it will just cause a mess. i wish my conduits were better located. the ones i put in both front and back of house are not in good locations.
    jim
    35x23/20 free form gunite 3.5-6 feet water. approx. 20,000 gallons. no spa or water features. 2 skim, 2 ret, floor ret, floor return. 2 inch solid. suction cleaning line. 1.5 inch solid. super blue diamond brite. NPT Gemstone Blue 2x2 with custom waterjet cut Disney Mickey markers. all pentair equipment. master temp 300,000 BTU. de 60. inteliflo 3.0 VS. swg ic40. 3 globrite LED lights. easy touch 4 with screen logic. tf-100/ salt kit
    Aug 2014
    Houston tx
    2,542
    My 2 cents. Master plan the whole thing- house and pool. If you already have your house plan and lot, then take that to a pool builder and start getting bids. That way it can be planned together.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Plan the wiring ahead of time. Meaning: oversize electrical panel to accommodate the pool equipment, or install the subpanel and wire it during construction. Then it's a simple matter to knock out plugs and add breakers. Also think about the equipment pad. There are codes relating to how far from a window you have to put the heater. Maybe you'll want to put the bedroom window in the other wall, so the heater can go where it fits best.
    Jun 2011
    Las Vegas, NV
    53
    Quote Originally Posted by Marlahoutex View Post
    Thanks to everyone; this is much more complicated than I thought. I'm glad I stopped by here - this is the best website for all things pool related.
    Since I've already got the pool construction company picked out (BYOP of Nevada), I'll have to retain their services to plan everything before we finalize details on the house.
    I now have a list of items to consider from the above posts.
    bdavis466's Avatar
    Aug 2014
    San Clemente, CA
    3,872
    Or you just pick a company that does it all
    -Brian-
