Results 1 to 10 of 10
Thread: My first TF-100 results
    Mar 2017
    Orange County, CA
    71
    Up until now I have been using strips which have kept me in a safe range. Of course I wanted more accuracy so I ran a test with the TF-100 today.
    Free Chlorine 1
    Chloramines 0
    Total Chlorine 1
    Calcium Hardness 475
    CYA 50
    pH 7.5
    Alkalinity 70
    Water temperature 68 degrees F
    According to pool math I need to put in just over a gallon of 8.25% bleach to get up to a Chlorine level of 4. Is that a good number for my pool?
    37000 gallons 45x20 vinyl liner
    Century 1.95hp SS pump
    Hayward DE4820
    Rooftop Solar heat with manual control
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    577
    Re: My first TF-100 results
    At a CYA of 50, I keep mine around 8 FC... or at least try to lol
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Dec 2016
    Arlington, Texas
    291
    With a CYA of 50, your absolute minimum for FC is 4 per Pool School - Chlorine / CYA Chart recommended level is 6-8. If you lose 2 FC per day, you should at least add to have 7FC
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Mar 2017
    Orange County, CA
    71
    Ok thank you. It looks like I need roughly 2.75 gallons of 8.25% bleach to get my FC up to 8.
    With a water temp of 68 degrees we are still a couple of weeks away from opening the pool. I'll bring it up to 8 tomorrow and retest Friday to see how much the pool is using per day.
    Hayward DE4820
    Mar 2017
    Orange County, CA
    71
    Added 3 gallons of 8.3% bleach yesterday and these are my readings 24 hours later.
    FC 4.5
    pH 7.5
    Temp 68
    Hayward DE4820
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,995
    Quote Originally Posted by Protlost View Post
    What does the water look like?
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Mar 2017
    Orange County, CA
    71
    It's very clear. I've been getting some dirt blown in to the pool lately because we're doing a remodel on the house. The trees tend to drop some leaves in to the pool as well. Basically if I dump the skimmer out every three to four days it's enough to fill a small soda bottle.
    I added half a gallon of 8.25% bleach today.
    Hayward DE4820
    Mar 2017
    Orange County, CA
    71
    Here we are a year later. The pool was using an abnormal amount of bleach and of course I was being lazy about my testing. After a full test it turns out the dilution due to rain and evaporation brought my CYA down to below 20. After adding 3.5 pounds of stabilizer here's where I'm at.
    3 Total Chlorine
    7.4 pH
    120 Total Alkalinity
    400 Calcium Hardness
    35 CYA
    81 Temperature
    We have hard water here so there's not much I can do about the CH. Should I add acid of some sort to bring my alkalinity down to the recommended level of 50 to 90? What kind of acid should I add? Out of curiosity why is high alkalinity bad?
    I'm using 10% bleach and will be adding another gallon.
    Hayward DE4820
    Mod Squad mknauss's Avatar
    May 2014
    Laughlin, NV
    10,990
    Higher TA will push your pH higher quicker. So no need to focus on the TA. When your pH reaches 7.8, add muriatic acid to take it down to 7.4 or so and your TA will be controlled. Your fill water is most likely high in TA.
    You should monitor CSI Pool School - Calcium Saturation Index (CSI)). PoolMath calculates it for you.
    It is not viable to measure a CYA of 35. The scale is logarithmic. So use 40 ppm.
    6000 Gallon IG Fiberglass with integrated Spa;Pentair CCP240 Cartridge Filter with Pentair Intelliflo VS Pump and HTR250 heater. IC40 SWG. EasyTouch 4. Dolphin Active20 Robot "Roadrunner", TF 100 Test Kit w/SpeedStir!
    CLICK HERE to Become a TroubleFreePool.com Supporter!! Pool Math App
    Marty
    Mar 2017
    Orange County, CA
    71
    Thank you for that info. I guessed at the CYA since at 30 I could see the dot but at 40 I definitely could not. I'll read up on the CSI.
    Hayward DE4820
