I have an 18x52" ultra frame as of now (build link with pics/descriptions in sig).. long term ill probably stick with this pool at least 3 more years, then maybe move to say a 22 or 26 foot or bigger pool..
My pool came with the intex 2100 gph 0.5hp single speed sand pump..
I'm about to replace this pump with a 4500 gph sky1639 best choice products 19" sand pump that is 1hp for $239.
In reading up on this, though, i'm wondering long term if this solution is the best and most efficient solution. I think from what i've read you can get the sand tank separate from the pump and add on a good pump.. however expensive.. ie: hayward pumps.
I also read that 2 speed pumps can reduce the electric consumption. I also dont see it much, but swear i had read that earth filters were the better bet all around?
Any suggestions for a more long term solution that can work for any size i may jump to.. i'm guessing the 4500 gph will do the job "okay" even in say a 26ish size pool.. maybe for now ill stick with the pending best choice but later on switch to a more modular setup?
Thanks for any suggestions in this area.
