Results 1 to 7 of 7
Thread: Season opener test results--scratching my head
    May 2015
    TN
    326
    Here's my test results:
    Fc 0
    CC 0
    pH 7.2
    TA 40
    CYA 30
    That all sounds pretty good... But I can't believe I don't have any CC's... Water temp was 60. Surely, I have CC's...
    24k gal. In-ground, vinyl. 2005 build
    Hayward Pro-Series S244T sand filter system
    Hayward motor & pump (rpm 3450,model SP2607X10)
    Polaris 280 w/booster pump.Taylor K-2006 test kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    10,729
    Re: Season opener test results--scratching my head
    Not necessarily. It is not unusual to have 0 CC and 0 FC. Once you raise the FC level you may see some CC develop.
    Love TFP? Become a
    TFP Supporter!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Agreed. Not enough Chlorine left to have either...
    Essential Links:
    May 2015
    TN
    326
    I slammed this morning at about 8 am. My slam level was 16. When I returned at 3, I rechecked FC and it had fallen to 8. CC was still 0.
    Water is pretty clear besides the bottom being a little dirty with trash sediment. Could anyone suggest where I go from here? Vacuum, get pool completely clean, and then re slam or just let it fall to correct FC level for a CYA of 40 and adjust pH and TA and go on...?
    Oct 2016
    Phoenix
    203
    Do the OCLT (Overnight Chlorine Loss Test) and see if chlorine is being consumed while the sun is not shining. If you are losing too much chlorine overnight then you should be SLAM'ing until you pass.
    "Sez the guy with only 50 posts...."
    Dave in Phoenix, AZ, USA
    12,000 gallon IG (5' max depth) , Pebble-tec,
    Hayward SP2303 Maxflo 1.65 HP, Triton TR60 sand filter, 1 skimmer, Pool Devil skimmer, 3 returns, 1 aerator port, Navigator suction-side sweep, Hayward valve actuator, Rainbird sprinkler timer used for valve automation and chlorine injection. Softened water used for makeup.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Ok, You have to follow the SLAM procedures until you pass all criteria. You're still losing Chlorine, and you just got started.
    Whats the hurry?
    Please review the SLAM articles and follow procedures to the letter until you are done. We will help, but you must do, and pass all until you're finished.
    Also, please understand. SLAM is a process over time. You don't do it, and stop, then do it again. As you were asking..."should I re-slam?"
    Essential Links:
    May 2015
    TN
    326
    Done the slam... water clear, overnight went from 14.5 to 13.5. I didn't get to ck it until around 730 this am due to youngins... and cc is zero. Slam is awesome!
    Are you guys still using the great value 8.25?
