Thread: Help with pump decision ...
    Apr 2017
    ojai, ca
    2
    Hello all,
    This is my first post, newbie here. I am replacing a 15 yo. old Hayward Super Pump II that is 2.5 hp. I was considering going to a Pentair super flo 2 speed 1 HP pump.
    I think my pump is oversized to begin with...i have a Hayward 48sq. DE filter and an in ground Spa that waterfalls into the pool.
    Would this new Pentair super flow 2 speed 1HP work? I found one on Amazon warehouse for only $350.
    My other thought would be to take advantage of the electric company rebate and buy a Raypak variable 1.5 hp for $500 and get a $100 rebate. Total $400.
    I lean toward a 2 speed and eliminate the electronics. But is 1 hp good enough?
    Thanks!!!!!
    Ken in Oak View, CA
    In ground pool, approx 22,000 gallon
    Spa
    Older Hayward Heater (rarely used)
    mas985's Avatar
    Pleasanton, CA
    11,986
    Re: Help with pump decision ...
    Is that pump used to run your spa jets? If so, do not downsize or the jets will get weak.
    Mark
