Results 1 to 7 of 7
Thread: Pump Leak
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Pump Leak
    Back at it from the winter.
    Have a small leak at the pump. Right next to wear my finger is in the image.
    Any ideas?
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Pump Leak
    Looks like a basic pump seal failure. You could try snugging up those 4 mounting bolts a little to see if they loosened at all. Otherwise, look for a seal kit for your pump model and replace.
    Isolated Spa - 345 Gallons
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Re: Pump Leak
    Quote Originally Posted by JVTrain View Post
    Thanks. I'll give the bolts a try. Any tips for identifying my pump if I need a seal kit? (I think I have a Hayward Super Pump.)
    Is a salt specific kit like this worth it?
    Saltwater Tune Up Kit Hayward Super Pump - GOKIT3SALT
    Saltwater Tune Up Kit Hayward Super Pump - GOKIT3SALT - INYOPools.com
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    Re: Pump Leak
    INYO has a good tutorial on how to do this...I'm in the same boat
    How To Replace a Pool Motor Shaft Seal - INYOPools.com
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Feb 2014
    Central Minnesota
    5,080
    Re: Pump Leak
    Thanks for responding SW... I thought I had...
    I don't have direct experience with a salt water kit being necessary. The website says that salt water can be more aggressive to rubber seals but at the relatively low salt concentration of pools, I'm not sure I buy it. For a pool situation, pH and proper chlorine use would have more effect on a seals durability than salt, imho.
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    Smile Re: Pump Leak
    I had a similar thought and went with the "regular" seal kit. If I decide to switch to Dead Sea levels of salt I'll reconsider.
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Re: Pump Leak
    Seal plate gasket/o-ring or shaft seal would be my guess. Either way you will need to take those 4 bolts out (if tightening them up a little doesn't work) and inspect the gasket around the seal plate and the shaft seal. One or both may be bad.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin S200 Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
