Thread: Cloudy Water
    Apr 2017
    Cabot AR
    1
    Cloudy Water
    I just filled my above ground pool for the first time this year. The water is quite cloudy. I am in the middle of correcting the ph and chlorine, but what should I do to make the water clear up?
    Stacy Beck
    Intex 14' x 42" AG
    Cartridge filter
    City Water
    Jun 2014
    17,323
    Re: Cloudy Water
    Hello Stacy from Cabot, AK. Welcome to TFP! Cloudiness generally points towards an algae problem. It doesn't start green, so now is the time to kill it. But you must have the proper test kit of your own. Do you have a TF-100 (link below) or Taylor K-2006? If not, that would be priority #1. Then you could post a full set of test result for everyone here to assist you with without guessing. In the meantime, don't' add anything to your water except perhaps about 1/2 gallon of regular (plain) bleach each evening. You should also read the SLAM page (link below) as that is the process we use here at TFP to eradicate algae.
    We'll help you through this Stacy. Nice to have you with us.
