Thread: Spa Losing Water when Pump Off
    Feb 2017
    El Paso, TX
    42
    As the title suggests, my raised spa is losing water whenever the pump isn't running. The level drops to jets but never gets lower than the jets.
    Of note the water loss occurs more rapidly when the Spa Suction Valve is left slightly open. But even when fully closed off the spa will still lose water.
    Is this a Valve issue or something totally different?
    Thanks in advance.
    Plaster, 2 HP WhisperFlo Pump, DE Filter
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,277
    Re: Spa Losing Water when Pump Off
    Chelsea,
    Most pools with raised spas have a check valve to prevent what is happening to you.
    I suspect the check valve is broken or has something in it that is keeping the valve from shutting.
    Post a couple of pics of your equipment pad and that might help us help you...
    Thanks for posting,
    Feb 2017
    El Paso, TX
    42
    Here is the picture as requested:
    Jul 2014
    Bedford, TX
    9,277
    Is that a check valve hiding behind the blue ball or does it have a handle on it??
    Feb 2017
    El Paso, TX
    42
    Here is a close up of it. It is on the return side of the plumbing.
    Jul 2014
    Bedford, TX
    9,277
    Looks like a check valve to me..
    Open it up and inspect it. If it looks ok, lube it up and give it another shot.
