- May 23, 2015
- 24,492
- Plaster
- Pentair Intellichlor IC-60
It is a known bug. It has to do with the fact that, under certain conditions of inputs, the carbonate portion (CO2(3-)) of the alkalinity drops close to zero and, for many of the parameters, their log value is calculated. Log(0) = infinity, so the calculation begins to break down. It's only seen in the cases of high borates (which few TFPers use) and very low TA (which is only the case for some plaster pool owners).
Your plaster will be fine. The most likely scenario is that your pool guy will act like a pool guy, think that what they learned in their 2 hour CPO class makes then an expert and then they start dumping all kinds of weird junk in your pool...
