Thread: Renovate
    smithamatic's Avatar
    Mar 2017
    stuttgart arkansas
    1
    Renovate
    Newer owner, I bought the House last summer and remodeled the house first, now im ready to move outside,, The pool was built in the late 70's, and the plaster is coming up in places. The Storage build sits on a pored slab, and is 12x20. The Decking is all wood, underneath is the original concrete 4'wide on the sides, and the ends are 10 foot wide. I want to make the storage building a poolhouse/guest cottage, and remove all the decking returning to a concrete deck, with the end 10x10 pads. Resurfacing the pool, and tile.. Have i lost my mind>?
    IG,16x33, 19700 gallons, concrete plaster. Hayward s244t pump sand filter. Hayward AquaNaut 200 cleaner. new owner, older pool.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Renovate
    Welcome to TFP!
    Yes. Sounds like a good plan to me.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,277
    Re: Renovate
    smith,
    Welcome to TFP... A Great resource for pool questions from those that have lost their minds...
    So to answer you question.. Yes, I believe you have... But, worth doing anyways...
    Thanks for posting the before pics. Can't wait to see the after pics.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,152
    Re: Renovate
    It will be beautiful a d lots of work. That quite a find, wood at the waterline. A gem.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
