Results 1 to 17 of 17
Thread: We need advice in North Texas for new pool.
    Mar 2017
    Sachse/Texas
    41
    Hi all, My wife and I have decided to take the plunge and have an in ground gunite pool installed. However this process has not started as smooth as we would have liked. So far we have met with 7 pool builders and we think we have finally settled on the one we like. Honestly, most of the 7 we either didn't like their design at all or they didn't listen to us as far as budget goes. We would like so advice on what you think about the design, what we are leaving out, and what we should be asking. I will attach photos of the design.
    We have to have the large wall and retaining walls due to the severe slope of our yard.
    As far as details we are sure of:
    Pentair VS-SVRS pump.
    Salt system
    DE Filter
    Stacked Oklahoma stone for the wall and retaining walls.
    Salt pitted concrete for the decking.
    Oklahoma flag stone for the coping.
    Tanning ledge on one end.
    3 Sheer descents coming out of the elevated wall.
    Our biggest hurdle at the moment is the decision of what type of plaster. The builder is pushing pebbletec for longevity as we don't plan on moving anytime soon if ever again... We don't know much about pebbletec and a couple of the other builders suggested Quartz? We are pretty frustrated as each builder seems to have their own opinion and they are always very strong in their opinions.
    So any and all advice will be appreciated!!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,319
    Re: We need advice in North Texas for new pool.
    Welcome to TFP... a Great resource for all new pool builders...
    First off.. do not get the SVRS version of the Intelliflo. It costs more, limits your lower RPM settings, and is unnecessary. The SVRS was a great idea when main drains only had one cover. The SVRS option kept people from getting stuck on the drain cover. This is no longer a problem because no one uses single cover main drains anymore.
    I love my saltwater pool and you will love yours also.. Just make sure that the SWCG is rated for 2 x the volume of your pool. So if your pool has 20K gallons, you cannot use the IC20, but must at least use the IC40 SWCG.
    I have the smoothest pebble finish they sell and still find it a little like sandpaper. You cannot tell by the 2" sample they show. You really need to go out and see a pool that has been completed and if possible walk on it.
    Here in Bedford, the city requires all DE filters to be plumbed to drain into the Sanitary drain for the house (Sewer). Not sure if Sachse does or not, but you might want to check.
    Thanks for posting and looking forward to your new pool build.
    Mar 2017
    Sachse/Texas
    41
    Thanks for the quick reply Jim!
    We will ask the PB about saving some money without the SVRS...
    We will also inquire about the size of the SWCG..
    What finish would you have used instead of a pebble product? We are also concerned about it being rough..
    Jul 2014
    Bedford, TX
    9,319
    We felt the little sample and thought "that's not too bad" and that is a far as we went... Sigh!!
    But all finishes have pros and cons.. I'm not really up on them, but we have a number of members that are. I'm sure they will chime in soon.
    Just from reading here quartz seems to have issues with having a uniform color and the darker the color the harder it is to be uniform.
    Let's sit back and see what our other members say..
    Jim R/
    Feb 2017
    Las Vegas
    885
    People like pebble because of the look that the finish gives (doesn't show mottling as much and the colors are more consistent) as well as the idea that pebble last longer than other finishes. For me personally I like the look of the mini pebble and the fact that you can add beads to really enhance the look of the water and give it some pop. The feeling on your feet is going to be a personal preference, most say they are not bothered by the mini pebble but if you have sensitive feet or you scraped your elbow you will feel the pebble.
    Be sure to get the largest filter possible so you will have less trips to the pad to clean.
    Also with the shelf I constantly read how owners wish they put a light on the shelf so the pool has even lighting. I would definitely look into a globrite there seeing as they are not to bright and don't take up a ton of room.
    You have a very nice design. I would recommend you look at the thread that grump started as it's very useful, I'm sure Kim Kim will be here shortly to link it for you
    current build<--free form gunite 34x21 18k gallons 4ft-7ft deep,Pentair 3HP VSP, wisperflo 2hp, 520 cartridge filter, 400k heater, ez touch 8 with screen logic, ic40 swg. 4ft sheer decent, 2 led deck jets, 5 globrite leds,rock spa waterfall. Mocha travertine deck, noche coping. Tropics blue custom mix with LOTS of beads and shells
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    34,010
    I would LOVE to see the yard this wonderful pool is going in! What a fun but scary time for you! We are here and can help.
    Here is the link Will talked about:
    All the things I wish I knew before our build
    Some good food for thought. Nice to hear from someone that has been there and done that!
    I can't wait to start helping you spend your money so you have the best pool on the block!
    Kim
    Mar 2017
    Sachse/Texas
    41
    Thanks for the info Will, we are trying to gather as much info as possible about pebble finishes. The pool builder we are leaning towards has also suggested wet edge so we are researching that also.
    Hi Kim, thanks for popping in! I will add some pics of the backyard in its current state tomorrow when the sun is out. And yes, this is a very scary and confusing time!! It's crazy how every pool builder seems to know whats best.. and they are all on different pages..
    Jun 2016
    Virginia
    118
    We just completed our pool with pebbletec in Tahoe blue with 20% glass beads ("luminous"). When we compared finish options, I thought the mini pebble (called pebblesheen) felt more abrasive (similar to sandpaper) than the larger pebble (pebbletec) so we opted for the larger one. The pebbles are rounded so they aren't rough to the touch, in my opinion, but if you were to scrape a wet knee or elbow against it you could get scratched. We chose the finish for the longevity and the color/look. We are happy with how it feels for swimming and sports in the pool. I also like that it is nonslip.
    Another plus is that pebbletec can only be applied by licensed pebbletec installers and the company tightly controls these. That can be a real asset if things do not go as smoothly as hoped with your pool builder. We had some issues with some of the subs used on our project but the pebbletec crew was fantastic.
    IG Gunite 20x40 pool with Pebbletec finish (Tahoe blue with luminous glass in mixed jade); Pentair DE Filter and Pump; Intellibrite LED lights; RayPac 8350 Heat and Cool Heat Pump; NPT Arctic Ice glass tile; Coverstar autocover; Cambridge Renaissance Pavers in Onyx Lite; bluestone coping.
    GDN's Avatar
    Oct 2016
    Dallas, TX
    308
    I'm in Far North Dallas, build started 2 years ago, so pool has been open about 18 months - just starting the second full summer. I checked out two companies and probably should have done more research and wish I'd found this site first, but I think all in all it's turned out pretty well. The first company didn't push any special plasters and the company we chose with uses PebbleTec.
    Of the finishes we did choose Pebblesheen. I had two friends both suggest to stay away from it because of it being rough. We really like it and it turned out very well. I don't consider it rough or abrasive, but I think after watching the process it is all about the installer. As noted above the installer should be certified and mine did a good job. I think the key to Pebblesheen is that it has to be worked a lot when being installed, this crew worked it a lot. I think the more they worked it - the better the pebbles laid flatter and became "smoother". It has a nice traction to it, but I don't consider it rough - we really like it, it just may not be for everyone. We wish we'd added some of the specialty reflective stones to it, but we didn't. We have a 6" deep sun ledge - you're welcome to come walk on it and see what you think if you are undecided.
    Greg -
    11K gal, IG Pebble Sheen (Aqua Blue) with sun ledge and attached spa, Pentair Intelliflow 3050 VS/SVRS (3HP), Pentair ET 8 with Screen Logic, Pentair Racer with 3/4 HP booster pump, 400KBTU Pentair Mastertemp, Pentair 60 sq ft DE filter, J&J Intellibrite LED in spa, Zodiac Nature 2 (not used), Stenner pump/liquid Chlorine, build completed in August 2015
    Mar 2017
    Sachse/Texas
    41
    Here are some pics of our backyard in its current state. Also, we made some progress today, our PB brought over some samples of Wet Edge and we love the feel of them. So hopefully we have found our plaster choice! We are thinking of extending the second step off of the tanning ledge up into the curve of the pool for more seating.. Any thoughts on that?
    Jul 2012
    Tallahassee, FL
    34,010
    OH I like that idea with the bench! The more seating in the pool the better!
    I like how you are using the back wall to take care of the slope problem. Well done! That is going to be so pretty!
    Kim
    Mothershipp's Avatar
    Jun 2016
    St. Augustine, Florida
    123
    We interviewed multiple builders but went with our specific builder because they offered PebbleTec and WetEdge. Other builders had pebble like options but with almost no difference in price we went with PebbleTec and the lifetime guarantee. Our installers did a great job and the more we brush it the better it looks in color uniformity.
    I find it a bit rougher on my knees etc if I'm diving for the basketball on the stairs or sun shelf but regular marcite would leave a good scrape too. I'm definitely a fan of the product and we've only been in our pool for two months
    Dream freeform pool 34 x 19 w/sheer descent waterfall, 7 ft spa with 6 jets W/ Jandy T3000 heater, doggie deck (sun shelf) with with Jandy Nicheless LED 9 w Watercolor light and a wrap bench to spa, 831 sq ft of paver decking ( Belgard Mega-Cambridge paver in Aragon), Pebble Tec finish in Midnight Blue with Shimmering Sea (abalone), I-Auqualink PS4 with spa side switch/remote. Pool and deck area to be screen enclosed.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,153
    On the second step extension, I'd extend it all the way over to the bench under the sheers. That will give you lots of places for people to sit and be facing back at the deck & shelf for conversation.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mar 2017
    North Texas
    43
    We went with quartzscapes reflections, Aruba Blue.
    We have swam a lot on Pebbletec; its just too hard on our feet. We like swimming on the quartz and love how it turned out in ours.
    Mar 2017
    Sachse/Texas
    41
    Update!
    We signed the contract. We made the change to the second step so it is more of a bench(pic included). We also decided on Wet Edge Primera for the plaster. Now we have to pick a color. We are choosing between Tahoe Coast, Azure Treasure, or Riviera Coast. If anyone has any of these I would love to hear about them!
    Also, we are deciding how to do the depth of the pool. The builder designed it with 3.5' at the steps and a gradual slope down to 5' at the far end. But, we are thinking we would rather have 3.5' at the steps down to 5' then back up to 4.5' at the far end. Anyone have any thoughts on that? Or how did you do yours?
    Jul 2014
    Bedford, TX
    9,319
    I,
    I have the play pool style where the deep "end" is in the middle. We (really the pool builder, as I had no clue) went with the standard 3.5, 5.5, 4.0. If I had to do it over I would have gone 4.0, 6.0, 4.0.
    What I have has never caused a problem, but I'd like a little more cannon-ball depth.
    Have you got the equipment list from your pool builder yet? If so we would be glad to run it though our filter to remove any PB speak...
    Jul 2012
    Tallahassee, FL
    34,010
    I like that step. Well done!
    I like the pictures of all of the colors your pick. I say you put them on a board and throw a knife them and see where it lands LOL You cannot lose!
    Kim
