Hi! I am having problems with air in my lines and infloor cleaning system not working. It started when I first noticed the cleaning heads not popping. A friend had a similar issue and thought the gears might be bad. I replaced the insides of the actuator but it would work for about 15 min when I first start the pump then the impeller would stop turning. I then started looking for another source to the problem and noticed air in the pump basket. I have tried the running water trick and thought possibly the drain plug was the culprit. I have replaced it and the problem remains. I cleaned off the o rings to the pump basket and leaf vac thinking I had too much old silicone glooped on and that actually made it worse. So according to a YouTube video it said you could test to see if an o ring is bad by putting on a bunch of silicone and see if it helps. I put a heavy layer of silicone on and it was better than when it was cleaned off but still some air coming in. Both the o-rings look fine but the one on the leaf vac seems maybe a little loose.
So my actual questions are-
Would you replace the o-ring next?
On a leaf vac should it be filled to the top with water? It comes up to the inlet pipe but isn't filled entirely.
Is it reasonable to think that the issue with the cleaner is related to the air or do I have two problems?
Any guidance is appreciated! I would really like to understand what's going on.
Also I have a pic of my setup but not sure how to post yet.
