Thread: Pool water fill valve? Fill port is not in skimmer basket.
    Oct 2015
    Dallas
    123
    There is a fill water port/pipe that runs from the outdoor spikett to the pool side. Is there some device that I can fashion to this to make it auto fill the pool as needed? I know of the float devices that work in the skimmer.. is there one that works for the side?
    the hose is burried under the concrete to the pool, but the first 5 feet is exposed and connected to the outside faucet through a splitter.
    Inground Gunite/Plaster pool with spa. Estimated 31,000 gallons.
    Apr 2016
    TX
    51
    Re: Pool water fill valve? Fill port is not in skimmer basket.
    Mo - 21K gal, IG plaster, dual Pentair SuperfloXF pumps, 72 sqft DE filter, cartridge filter for the spa, dual Waterco multi-cyclone prefilters, Dual Circupool SWGs, Polaris booster and cleaner, TBD custom controller.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    This one, https://www.amazon.com/Premium-Stayp...YM9G31AZ5KQY6D is just some pvc and a $10 stock tank auto filler from Tractor Supply like this Little Giant Trough-O-Matic Plastic Float Valve - For Life Out Here
    I think I might just put a hose timer from Lowes on the faucet and set it to run some number of minutes per day. Shop Mister Landscaper 1-Program Digital Hose End Timer at Lowes.com
