Pump is running fine... water movement is not strong and the cleaner (Polaris) is not moving well. I replaced the cleaner in the fall and it is in top condition. I sprayed off the filter grid panels but the water flow is still low and it is not cleaning. Also, since the panel cleaning the panels are not collecting much debris.
How can I tell if I have a crack in the grid assy or if I have a damaged panel? My research points to that possibly being the problem.
small pool, < 10,000 gal.
Jim
Jim
