Results 1 to 8 of 8
Thread: Does this look normal??
    Ready2swim's Avatar
    Jan 2017
    Hallsville, Texas
    13
    The pool builder hooked up a pump and was able to pull majority of the water from under the pool and the pool was plastered Sunday. It was finally full this morning at 3am. They are coming tomorrow to start the pool. Since two of the three kids are home sick I decided while they were napping to test the water. Here is what I got, does this look about "normal"? "Normal" as in not treated with anything yet.
    Ph-8.2+. (It was darker than 8.2)
    Chlorine -0
    Bromine -0
    CHT- 25ppm
    TA- 370
    CYA-0
    16 X 38 Roman shaped plaster pool (3.5' in shallow end, 8' in deep end), tanning ledge with lighted bubbler, Pentair WhisperFlo 2HP pump, Pentair 100D Sand Filter, Pentair intellichlor Salt Generator, Pentair Glo-Brite Light, Pentair Color LED Bubbler, Pentair Kreepy Krauly Prowler 820
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,091
    Re: Does this look normal??
    If by normal you mean what I would expect a newly plastered pool to look like, yes
    Don't do anything to void the warranty, but that ph needs to come down rather quickly. It will want to rise for a while, keep it in the 7s.
    That TA is incredibly high, but don't worry about that for now. Just get some acid in there, tomorrow (72 hours from plastering) get a little bit of chlorine and a little bit of CYA in there.
    Relevant article Pool School - Start-up New Plaster
    Also, you could add your state to your location and fill out your signature
    e: This is all assuming you are using a TF-100 or Taylor 2006.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Jan 2012
    'burbs of Augusta, Georgia
    8,587
    Which test kit are you using?
    You wrote "CHT"--do you mean CH (Calcium Hardness)?
    You don't plan on adding Bromine to the pull, right? Don't ever worry about the BR side of the comparater block. Just CL. Or better yet the FC and CC from the FAS-DPD test (the powder and R-0871 reagent test)
    The TA appears really high but I don't believe that is accurate. The PB may have put in something that causes it to be wonky.
    Ask the PB what he wants you to do about that high pH? Does he expect you to take over yet or will he? Muriatic acid is the cure for that pH. Bring it down to 7.5
    Yip
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Ready2swim's Avatar
    Jan 2017
    Hallsville, Texas
    13
    Thanks so much, I am using the TF-100 with a speed stirrer.
    We will not actually take over care of the pool until after the first 30 days. I think they thought it would take longer to fill than it actually did because he said he would be out tomorrow, really wish it was today. I was just wanting to make sure it looked like I ran the tests right, which maybe I didn't on the TA, I didn't think it would ever turn red!!
    I will go set up my signature. I am still learning my way around
    And yes CHT is Calcium Hardness, not sure why I put the T on there!
    30,956
    It is fine to let TA be the last thing to adjust. Do the pH first using muriatic acid to lower it to 7.4 or so.
    Do you know how to use PoolMath?
    22,703
    Since this is a brand, brand new pool and you've already stated that you're not supposed to take over maintenance until after 30 days, I'd call them and make sure that they're ok with you adjusting the pH without them being there. It most likely is, but better safe than sorry in this case.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,344
    When you call or text about getting permission to adjust the pH on your own, let them know you have a test kit, a Pool Math calculator for how much chemicals to add, and a team of pool experts to guide you in making adjustments. You may have already talked to your PB about that. I did a lot of talking about TFP to the guy in charge of our pool the first 30 days. I showed him my kit, and showed him my paper logs of test results I was running from day 1 of the fill. After a few days, the guy told me to go for it. He said I seemed to know more than most new owners, and he felt reassured I had the TFP experts to help me and that I texted him the test results at least once a day with what I planned to do. He also liked that it meant he only needed to check on me once a week the first 2 weeks. He did keep coming out once a week adding the darn chlorine pucks, but they were still not adding enough chlorine to the new pool. I'm so glad I had TFP to make sure the pool didn't go green.
    The testing gets easier and easier - and very quickly, too. (LOL!!! I can still remember my heart was beating so hard the first time I tested the water!! But keep that a secret! Now it seems funny!) You'll be a pro in no time at all!!!!
    Suz
    Suz~Cypress/Houston area~ My 2015 Pool Build. 24K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy; color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. TF-100, SpeedStir
    Jan 2016
    Mesa, Az
    560
    Use care when adding acid to a pool with no circulation. Acid is heavier than water and will sink and "bloom" out over the bottom, leaving a higher-than-desired concentration at the bottom of your pool. IF you do add acid, do it in small increments and agitate the water by brushing or with the skimmer hoop between applications.
    17' x 30' rectangle pool, two 7' x 7' baja decks, 6' x 8' raised spa. Hayward 2HP VSP for features, filter and returns. 2HP single speed for 9 spa jets. 1HP blower for spa bubbles. In-Floor cleaning, Cartridge filter, AquaConnect automation, 400K BTU NG heater. Plaster is Stonescapes mini-pebble in Aqua Blue + abalone shell TF-100 Text from Neighbor -- They're digging your pool!
