Thread: Can I store chlorine in a brand new 5 gallon plastic gas can?
    Sep 2016
    Katonah NY
    172
    Hi,
    Is there any risk of bad things happening if I were to use a 5-gallon brand new plastic gasoline tank to store chlorine?
    The gas can would be out of sight so no risk of someone accidentally filling their car with chlorine period
    I would plan to rinse the gas can out a number of times before using it even though it's brand new
    Thanks
    Rich
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Can I store chlorine in a brand new 5 gallon plastic gas can?
    Other than it being poured into an engine there's no risk I can think of. Rinse isnt needed in my opinion but it wont hurt. Id still label it bleach just incase...
    Essential Links:
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Yes, I'd definitely put some labels on it.
    30,955
    Some cans nowadays are vented. You will have a chlorine smell if your's is.
