Results 1 to 12 of 12
Thread: Has anyone seen this in the skimmer?
    Mar 2017
    Brandon
    3
    Hi Everyone,
    Noobie here, trying to figure out what is on the left side there (skimmer return side) from a newly acquired pool.
    Not coming out easily by hand. I'm looking to add a diverter valve and this will be on the way.
    Thanks for looking!
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    Re: Has anyone seen this in the skimmer?
    A,
    Welcome to TFP... A Great resource for all you pool and skimmer questions..
    I have no idea what that is, but wanted to confirm that your main drain is plumbed into the bottom of the skimmer...
    The only reason I ask, is that this hole will be plugged if the main drain is run back to the equipment pad.
    Thanks for posting,
    Mar 2017
    Brandon
    3
    I believe right side goes to main drain because when looking back at my pump, there is only one pipe coming in, although after the filter there are two pipes (I think this is just to divert the flow around the pool)
    I'm afraid to use force there since I'm not yet sure how the whole assembly is put together or what that white piece could have been originally or what goes there?! Shouldn't both sides look the same?
    About me: Apprentice pool owner (1st year) - Please be patient with me
    My pool: 14x20x5 inground pool hayward accessories.
    Jul 2014
    Bedford, TX
    9,297
    A,
    If you only have one pipe into your pump, then it is a pretty safe bet that the main drain is plumbed into the skimmer.
    Many, many older pools are plumbed this way. I have two of them and neither has a diverter valve.
    Main drains are not really needed, so why are you interested in adding a diverter plate?
    Sorry, but I have no idea what could be in the pipe..
    Let's see if one of our other members can chime in..
    I suspect that it’s a Skimmer Adapter for a Suction Side Cleaner.
    Support the site
    Jul 2014
    Bedford, TX
    9,297
    James,
    Do you think it screws in or what??? I've never used one.
    I suspect that it’s probably a push in adapter.
    To the OP: Do you have a cleaner?
    Support the site
    Mar 2017
    Brandon
    3
    Thanks JamesW, I suspect the same. I bought a cleaner and was able to attach to whatever that is, it doesn't go right in but it snuggles well enough for the cleaner to work.
    Jimrahbe if you think I don't need the main drain, what would be the proper way to close it out? That would solve my problem, as I'm trying to increase surface filtration. I think what I meant was a skimmer diverter plate
    Jul 2014
    Bedford, TX
    9,297
    A,
    I don't believe that installing a diverter plate will improve your skimmer operation. Without a plate all the water is coming from the skimmer opening, the main drain is not being used at all.
    My guess is that your Weir door to the skimmer is missing... The weir door is what makes the skimmer work..
    Aug 2016
    Riverside, CA
    378
    I grew up with a pool built in the early 60's and it had no weir door but it seemed to skim just fine. I'm not sure why but it did..
    Jul 2014
    Bedford, TX
    9,297
    Sammy,
    Skimmers will work without the weir door, but they work better with the door operational. Without the weir the water is pulled more from the bottom lip of the skimmer, with the weir door installed the water is pulled more from the surface of the pool.
    Aug 2016
    Riverside, CA
    378
    Quote Originally Posted by Jimrahbe View Post
    Sammy,
    I see how they work a whole lot better for sure. I'm just pointing out that my dad's pool didn't have one and it still skimmed. Mine can sometimes draw air even with the weir door and IIR his never did that. In my teen years I was the pool guy BTW..
