Results 1 to 9 of 9
Thread: Zero Suction
    Mar 2017
    Miami/Florida
    4
    Zero Suction
    Have fine water flow on main drain, as soon as I open skimmer/vacuum line, the flow disappears completely. Regular pool service and others I've called can't find a problem - no leaks, no clogs, etc. Have closed main, turned off pump and with suction line open, can run water through it and into pool continuously. All seem baffled. What are we missing?
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,248
    Re: Zero Suction
    K,
    Welcome to TFP... A Great resource for all your pool questions...
    Well for sure that does not sound right. How about a picture of your equipment pad showing us the piping and valves associated with the input to your pump.
    Also.. Is this a new pool, if not, about how old is it? Has it worked before and suddenly quit working?
    When you say Skimmer/Vacuum line, do you mean you have a Skimmer and a separate Vacuum line? Or do you mean that you connect your vacuum to the suction port under the skimmer basket?
    When you look under you skimmer basket, there are two holes/ports. Are both ports open or is one of them plugged.
    What you say makes no sense, so I'm just looking for more facts that might point us in the right direction..
    Thanks for posting,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Zero Suction
    Sounds like there is a suction leak on that line. More here, Pool School - Suction Side Air Leaks
    Mar 2017
    Miami/Florida
    4
    Re: Zero Suction
    Pool built in 1994. Everything working fine until a couple weeks ago - had to change diaphragm on barracuda - after I took vacuum out and did that, flow stopped.
    Have not been able to prime since. Water flows fine with main drain open. As soon as I turn valve for vacuum even slightly open, flow stop.
    ** Says I do not have permission to load pictures
    DFW, TX
    24,974
    Re: Zero Suction
    There is limited space for uploading pics, maybe they are too big? To get more space for pics and other benefits go here, CLICK HERE to Become a TroubleFreePool.com Supporter!!
    Or
    You can upload pics to Photobucket or another pic host, copy the IMG code and paste it into your post so that the images can be viewed in your thread. More here, Posting Photo's Tutorial
    Jul 2014
    Bedford, TX
    9,248
    Re: Zero Suction
    K,
    How does everything work with the cleaner disconnected?
    Mar 2017
    Miami/Florida
    4
    Re: Zero Suction
    Still no go with cleaner disconnected.
    Pics : Pool1 — imgbb.com Pool2 — imgbb.com
    Re: Zero Suction
    The picture shows 3 suction lines. Which line is the vacuum line?
    If you have all three lines open, does the pump run with full prime?
    If you have only the skimmer and main drain open, does the pump run with full prime?
    The valve on the left is missing the grease port fitting. Those can break off and cause an air leak.
    Try rigging a garden hose into the vacuum port and pushing water into the pump. You just need a few fittings.
    Make sure that the vacuum line valve is open when using hose pressure.
    Support the site
    Mar 2017
    Miami/Florida
    4
    Re: Zero Suction
    Quote Originally Posted by JamesW View Post
    Vacuum is middle line. With valves turned as in picture, water is flowing (main open, vacuum and skimmer closed = no suction).
    As soon as I even slightly open valve to suction, all flow immediately stops , not even a trickle slow down - no main flow, no skimmer suction, no vacuum.
