Scooped out all the floating mess i can see so far, got the brush out and cleaned up the side tops a little. When brushing its breaking up the big pieces so im going to leave it a few hours to see if any more large junk floats up.
Pump and filter i assume are working fine (only one way to tell i guess!)
Question:
You mentioned running the pump in recirculate, i guess this will basically bypass the filtering system and mix up the water? The pieces of junk are fairly big.... will there not be a possibility of getting clogged up somewhere?
Question:
