Thread: pebblesheen vs pebblebrilliance for bright blue
    Mar 2017
    midwest
    1
    Wanting a bright blue water appearance (no green). Which colors would you suggest as a place to start? Do you prefer the sheen or brilliance.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: pebblesheen vs pebblebrilliance for bright blue
    Welcome!!
    The only finishes that make water appear Green are the Sand, Tan, Brown colors. Hitting on your theme, there are loads and loads of colors you could choose for bright Blue water.
    Essential Links:
    wjr75's Avatar
    Jun 2013
    IL
    866
    We have the Aqua Blue Sheen and love it. The Brilliance line must be something newer. The pebbles look bigger than the Sheen pebbles.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Aug 2014
    Houston tx
    2,542
    I think the Brillance is a mix of beads and pebbles.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
