OK, so it's dripping from the coupling. Good news is that it's above ground and easy to get at
Unfortunately there's no unions on the pump, or it would be super easy, but it's still pretty straight-forward to do PVC pipe fitting and fix that. Total materials is under $20. You could re-do the pump with unions at the same time for maybe $40 in supplies. Have you ever glued PVC pipe or electrical conduit? If not, happy to walk you through it. In a nutshell, you'll cut out the bad bit and reconnect with good joints. Or you could get a poolie to do it, maybe $100 to $200 depending who you know or if you can get mate's rates.
Im sure it's something I'd be able to tackle next weekend or after work one day.
Now my aerator valve handle is broken? And leaks slightly from there as well. Is it the same idea as replacing the coupling? Just smaller piping
