You may want to key an eye on the pH level for a few days. If you see it up one day and down the next you may need to increase the TA a bit.
TA at 30 is low, but also be sure the sample is up to the upper line (high sensitivity). Telling us the quantity of chemicals added is also helpful to know.
Hey MissFancypants,
[FONT=&]With the ClearChoice kits. If the solution turns purple there are steps you can take that might help. Using the instruction sheet (the laminated one for Calcium, not the sticker on the lid) included in the kit, start the test again, this time adding 5 drops of calcium hardness titrating reagent after step 2 and before step 3. Then proceed with step 3 as usual. Add the five drops to the total obtained in step 6. Apologies if you've already tried that. If you have, you can test using the CH standard and make sure the reagents are all working ok.
If you need help with the steps or it's still not working let me know but I'm sure you'll get seriously expert help from the TFP crowd as well [/FONT]
Thanks Aus for the calculations, now, I'm having probs with the CH test it turns purple with particles in it, even when I do the sensitive test after 2 drops not blue so i'm not sure what to do with that?
Everything else has been stable, ph sits at 7.4
Hey MissFancypants,
Hi Brett I did try what was suggested on the laminated sheet but still got the same purple, I also tested the sample and that turned blue so its my water, does it have to turn blue? Thanks for your help
Have you added any calcium since the refil?
Hey MissFancypants,
Yes, it should normally turn blue, that's the tritration end point. The point where all available calcium has reacted with the titrating reagent and the number of titrating drops x 10ppm = the calcium value for the sensitive test. But something is not normal. I suspect you have interference from metal ions, your 0.04mg/L of iron. And if you haven't added any calcium since the refill then you also have a very low CH level, 90ppm or less.
By 'sample' I assume your talking about the standard solution that came with the kit?
Heres a Taylor clip for the CH test with interference
The Taylor R 0012 is the same as the CCL titrating reagent and their red 'looks' a bit purple or purple/red to me.
This is what it looks like after I add the titrating stuff, thats after 4 drops and its goes purple from the 3rd one
I did test my water from the tap and it flashed purple then turned blue so I'm thinking its from what I ve put in the pool, I'm not really worried about the calcium hardness as the pool is seasonal and theres no staining or build up on anything so it hopefully its in a safe range
Yes the sample in the kit, my test works exactly as yours Needsajet, until the titrating agent then I get the pretty purple colour
