My pool was neglected for several years. I've finally decided to start cleaning it up. After about a month of struggling on my own, I decided to quit skulking around the website. I feel like 30gal of 8.25% bleach was quite a bit, especially since PoolMath says 2 gal of 8.25% should boost to 10ppm. I'm curious to see what the recommended course of action is. Should I just start over with the SLAM process? Any advice is greatly appreciated.
Current pool state:
Cloudy blue water, visibility is about 8-12 inches. Note: Floc was applied 24h ago, still cloudy.
Current test results:
FC - 0.8 ppm
TC - 1.4 ppm
PH - Acidic (12 drops to get to 7.4)
TA - 30
CH - 450-500 (450 may have had slight purple to it, 500 was notably blue)
CYA - ~50
Here's a description of what's happened so far:
Current pool state:
FC - 0.8 ppm
TC - 1.4 ppm
TA - 30
CYA - ~50
- Skimmed bottom with a net to no success. It seems that I've had bad blooms, but few leaves/sticks due to our screen enclosure.
- Began hitting it hard (with rough timeframe estimates)
- Day 1
- Pool state - Deep green color, couldn't see bottom
- Start running filter 24/7
- Vacuum to waste
- Chlorine dump (9 gal of 8.25%)
- Day 2
- Pool store - CYA = 0... Chlorine dumps (9 gal of 8.25% [3 gal every 12h])
- Brushing
- Day 7
- Pool state - Blue/Green color, couldn't see bottom
- Vacuum to waste
- Chlorine dumps (9 gal of 8.25% [3 gal every 12h])
- Day 10
- Pool state - Notably blue, yet extremely cloudy
- PH is acidic
- Day 12
- Pool store
- 'Cloudiness is dead algae! Clarifier is what you need!'
- PH is low, base is what you need!
- Phosphates are high. - I ignored this due to knowledge I've gathered from the Forum
- CYA = 30
- Added PH up
- Pool store
- Day 13
- Still acidic, added more PH up
- Day 14
- PH good (~7.3?)
- Added Clairifer
- Day 17
- Slight noticable difference after first Clarifier treatment
- Added more Clarifier
- Day 23
- Pool state - Still blue, still cloudy
- Give in and hope to god the cloudiness is algae
- Day 25
- Apply Floc
- Ran filter for 2h and now stopped
- Apply Floc
- Day 26 - Today
- Awaiting (and hoping) Floc to settle (24hr passed now)
- Day 1
