Hi everyone.
Thank you for the wealth of information posted on TFP. I've learned so much in the past couple of months. After reading as many TFP posts as I could, I think I'm ready to get my own pool. I chose my PB yesterday and I'll be signing the contract very soon. If things go well, it'll be done by Christmas. Thanks for any feedback.
- Pool Dimensions 24x40
- Pool Square Footage 741
- Pool Linear Footage 106
- Pool Depth 3.5 to 5ft
- Coping Type: Flagstone
- Install your choice of our standard 6" waterline tiles.
- Install Shamu Pad ledges, benches, and steps per plan. Shamu Pads come with an umbrella sleeve and two (2) bubbler fountains.
- Skimmers 2
- Pressure Tested Schedule 40 PVC Pipe
- Main Drains 2
- Returns 4
- Textured Concrete Decking 500 Square Feet with PVC Expansion Joints to Match the Concrete
- 4" CPVC Deck Drain Pipe 50 Linear Feet
- 8" Area Deck Drain 3
- Install a 24" high medium stacked rock raised bond beam with a safety grab ledge on the bottom of the raised bond beam.
- 4,000 PSI pneumatically applied concrete reinforced with a rebar cage tied 12" on center with a three row steel reinforced 12" bond beam.
- 18" Sheer Waterfall 3
- Bubblers 2
- Waterproof the pipe penetrations, light niches, and skimmer equalizer lines. Install fittings to match the interior finish on all of the pipes leading into the swimming pool.
- Install an exposed aggregate pebble interior finish. Pebble Tec, Pearl Matrix, or Satin Matrix
- Pentair Easy Touch 4 Function Automation System with Salt System IC60
- Pentair SUPERFLO Variable Speed 1.5 HP Pump
- Pentair/Sta-Rite Modular Media 500 Cartridge Filter
- Pentair Intellibrite 5G Color Changing LED Lights 3
- Install a bonding grid per your jurisdiction electrical code, bond the pool, wire in all included pool equipment and accessories.
- Sub Panel/Meter Tap
- Freeze Protector Circuit
- Backfill the pool and return the construction area to a rough grade and ready for your final landscaping grade.
- We will perform standard permitting for the project. Permitting will begin when the start date timeframe is determined, a contract is signed, deposit received, and survey/plat received. The customer will provide us with any required property plats/surveys.
- The project completion time will be 8-10 weeks and begins on the morning of excavation and ends when the pool is filling with water.
![ScreenHunter_05%20Sep.%2016%2008.29_zpssyw3ulqy.jpg](http://i1079.photobucket.com/albums/w515/gitpark/ScreenHunter_05%20Sep.%2016%2008.29_zpssyw3ulqy.jpg)
![20160916_091437_zpsij3vfo0o.jpg](http://i1079.photobucket.com/albums/w515/gitpark/20160916_091437_zpsij3vfo0o.jpg)
![20160916_091405_zpsovuiawnc.jpg](http://i1079.photobucket.com/albums/w515/gitpark/20160916_091405_zpsovuiawnc.jpg)
