HI Pooldv, Marian
I just got back home, got up early and went to the house so I didn't check this board till now. Today I turned 57 and my 3 YO grandson and son came over to help paint and work on the pool. I didn't let him go in though, the FC is still 26 and I wasn't sure about it. The water looks great= clear to the bottom and no algae seen today at all. I dumped some more water out and added fresh city water.
At 8:30 pm last night my FC was 29.5 ppm. The CYA I measured was 50 which I was surprised at so that could be wrong but I checked it 2-3 times. I wanted to get back today before the sun hit the pool but I didn't make it. I got there at 8:30am so the sun hit the pool for an hour or so. I ran through all the tests again to see what happened over night.
FC down to 26.5 so I don't know if the sun was hitting it or if it still was killing algae in the water?
TC -0-
CYA 70 this seems more like it but last night I was pretty sure it was 50. I haven't checked it since I dumped more water today.
PH 7.5
TA - 100
I wanted to keep the shock going so I added 32 oz of 12.5% shock and let it go till 2:00 pm.
The 2 PM test was still 26.5 FC CC-0- no more shock added. dumped and filled more fresh water. Went back to painting.
7:00 pm
FC still 26.5 sun hit the pool day no change, is that because of the 32 oz I added 10.5 hr earlier or the SLAM is done? CC -0- still. The pool is as clear as tap water now. I am really impressed on how this all worked out and couldn't have done it without your help.
If the SLAM is done I will continue to dump water a little at a time to get the CYA down and maintain the FC level based on the CYA. I left the filter running 24 hours since thurday and
brushed the pool everyday. Previously the filter was set to run 12 hours. I don't have the spec's on the pump or filter, I was going to see today but forgot. What is your thought on setting up the filter after a slam? I haven't had to backflush yet either, psi is still 10 psi.
Roofing in TX, good luck brother. You must get up and out while still dark to get down before high noon? We get 4 seasons up here, each one about 3 months. Sept to Nov is the best weather, not for swimming, but in the 60's dry and crisp. Not until Dec does it get old fast, cold and snow till March.
Thank you
Gary
