I have a SR Smith Vortex slide that requires a max of 30GPM for the water supply. I currently have it plumbed via a 3 way valve from my 2 hp main pump which runs both the pool and spa. The issue is that I can't run the slide and heat the spa at the same time. My plan is to add a new 110v pump dedicated to just the slide. I will use the bottom drain to feed the pump. The drain is 10 feet below and 30 feet from the pump location. What pump would you choose?
