I've been having issues with my booster pump leaking from the bottom (the small rectangle opening between the front volute and the motor). After some research I decided to change the shaft seal and o-rings as recommended. Pretty straight forward repair but after waiting an hour or so when I powered it on, it was still leaking a good bit from the same spot. Did I do something wrong or is there possibly another issue?
