Getting together my material list for putting up our brand new, first-ever pool.
Intex 15'x48" Ultra Frame AG. Listed as 4,440 gallons. Stock filter pump. Planning on leaving up permanently.
I will be leveling myself - what kind of tolerance in variation is acceptable/best? An inch, 2 inches?
After cutting sod, I'm going to spray roundup.
I have purchased rigid foam board. Do I need to add sand before the foam? Foam is 1-1/2" in thickness.
Or will the foam even out the low and high spots?
After the foam, use...? I've read MANY things on here and I'm confused.
The pool came with a ground cloth- use that on the foam? Purchase a gorilla or elephant or happy bottom?
I have also planned on cutting out foam for my 1-5/8" patio blocks to go under the legs. Is this best or can I just let them sit on the insulation?
Im drowning in info and have a little bit too much "perfectionist" and worry in me. I over build everything.
Any help and opinions is great and much appreciated! Thanks, Casey.
