That sounds great. Yes, you should be able to let the FC level come down on it's own now. Keep an eye on it. If the algae is all dead the water should clear up noticeably each day.
Thanks, glad to see I'm starting to get my head around the ideas on this... It will be hard to see the water get much better as it really looks nice now, at least except when the robot finds a crud patch...JasonLion said:That sounds great. Yes, you should be able to let the FC level come down on it's own now. Keep an eye on it. If the algae is all dead the water should clear up noticeably each day.
Gooserider said:Thanks, glad to see I'm starting to get my head around the ideas on this... It will be hard to see the water get much better as it really looks nice now, at least except when the robot finds a crud patch...JasonLion said:That sounds great. Yes, you should be able to let the FC level come down on it's own now. Keep an eye on it. If the algae is all dead the water should clear up noticeably each day.
One minor thing I've noticed when testing, is that if I leave a DPD test sitting in the vial after getting the two changes to clear for FC and CC, it will turn pink again after a few minutes... Is this normal / OK? What is the process that makes this happen?
Gooserider
JasonLion said:Getting just a tiny bit of CC is common for some pools and doesn't pose any problems. Running with FC just a little higher than usual for several weeks will sometimes get rid it, but sometimes it sticks around more or less forever.
JasonLion said:Given the large quantities involved, and the higher cost of dry acid, it is better not to use dry acid.
10 lbs of dry acid is about the same as one gallon, minus one cup, of muriatic acid.
Gooserider said:OTO cl - 1 (I'm having a hard time reading that block!)
pH - 7.5
DPD
FC - 1.5
CC less than 0.5
TC ~2
TA - 140-150
CH - 280-290
Those last two tests I have a bit of a question on when to count the completion - seems like I will have a range where one drop takes the solution from the starting color to an intermediate "greyish" shade but NOT to the "end point" color, however a very definite color change, and the next drop goes to the "end point" - which drop is the one I should count?
looks to me like (and the pool calc agrees) I need to add about 1/2 gallon each of Chlorine and acid, and keep aerating like mad to get the TA down...
Currently my CSIC seems to be a bit OK at -0.04, but dropping the pH down will push it out of range to -0.88, is this something to worry about? Presumably it will come back up as I get the TA down....
Gooserider
frustratedpoolmom said:You don't need to test the CH often anymore, provided your other numbers are in range, and you aren't using any products like calhypo. Monthly ought to do it.
I saw notes that the CYA will impact my other numbers, but I don't think it will be a big factor, will see what things look like tonight... I was looking to get the TA to around 80, as the PC says my goal should be in the 70-90 range. I dropped pH down to a calculated 7.0 again last night and have been aerating steadily, so hopefully it should be about right by now - I was thinking that I would probably be about right tonight anyway.Note, adding CYA will lower your PH and TA some. Keep that in mind.
Also, have you tested the borates yet? Have you reached your target? Because TA of 100 is perfectly fine, especially if you don't have an SWG.
No problem, perhaps someone else has an idea, or I could always use the search to see if it's been discussed to death already... :lol:I don't have any tips on 5 gallon drums, sorry- never used em.
frustratedpoolmom said:I'll be honest. I don't test every day. Shhhh...don't tell the other Mods. They might take my Pod away.
aha! I don't test every day, either :lol:
