So I did another water test to be sure. I did not add any Borax, and my wife says I can't see the color for the PH. She says it's 7.2 because it has some pink in it.
Am I doing this next step correctly? Pool math tells me that TA is outside of range. So I click on it, and it tells me to lower it with acid and raise it with air. I then went to PH, and it told me to add 5 lbs, 11 oz of Borax. It also tells me to add 2 lbs, 10 oz of a stabilizer. Am I using pool math correctly? Do I need to only worry about the red warning symbols or the blue ones also? My latest tests are attached, but I think you can see them. Thank you for your time and patience. Dusty
