I need to reseal my fiberglass step insert to the surrounding concrete. What is the best sealant to use for this job?
Philip
Philip
Thanks, cowboycasey.
That is some serious looking stuff! I'll see what I can find out from pool builders and will report back here.
Philip
A pool builder I contacted recommended filling any voids with play sand up to a half-inch from the top, then filling this half-inch void with self leveling concrete sealant available from Home Depot.
I'll give this method a try and report back here when finished.
Philip
This must be a top, horizontal seam then. I was thinking it might be between the bottom of the coping and top of the steps which would require something different from self leveling.
I do recall this same builder used silicone sealant to seal the underwater vertical seam where the step insert joins 3 pieces of trim that separate the step insert from the vinyl liner.
Philip
That sounds like an expansion joint and it should be filled with sand and/or foam backer rod to about 3/8-1/2" depth. Then the joint should be filled with self leveling polyurethane caulk. My PB uses Sikaflex brand.
Hi pooldv,
This is a tardy follow up, but that is basically what I did. After removing what was left of the old sealant, I filled the void between the step insert and the concrete with sand (this seam varied in width and depth, and there was no expansion joint material that I could see). I then used a toothbrush to achieve the correct depth with the sand. Sikaflex brand is the one I used. It is self-leveling and for use in horizontal joints only, but I experimented with this stuff and found that by holding the nozzle against the steps during application, it worked great. The stuff exits the tube in a semi-liquid state and sticks where it is applied, but after a minute or two, it goes into a more liquid state and the "self-leveling" feature really kicks in. This created a really nice cove joint between the vertical pool step and the horizontal concrete.
I stuck around to watch the stuff do its magic. I had some low spots develop where more material was needed; adding more material was easy to do because nothing had set up yet. I was also able to clean up any mistakes and some overflow by wiping it up with paper towels before it started setting up.
Thanks everyone for the input!
Philip
