I'm a bit confused, eos, as to why if your running your pump for 10 hrs a day, why you're only running the swg for 7.5 of those hours? No energy savings there.
Jason's calculations, which were spot on, show that even if you ran the swg for 12 hours at 100 percent, you'd only be generating about 2.8 ppm of FC. It would be perfectly normal on a sunny day to need that much.
So for easy math, dial Er up to 12 hrs at 100% and see if your readings are stable from one day to the next. If the FC climbs above your target level, use that days reading to estimate how much your pool "used" then dial down accordingly either by percentage or run time. Make sense?
Once you get this dialed in, you will barely have to think about it and rarely change it. With your size of pool in gallons, versus the capacity of your swg, I would just run it 24/7 on party weekends. Extra filtering never hurts after a party
The way to think about the swg is that it produces a fixed amount of FC over a fixed amount of time. That's the job its great at doing, and as long as you run it at recommended levels, that's usually the end of the story.
But if you let it run too low or too little in terms of time so tat it drops belw range OR (and) starts developing nascent algae and a higher chlorine demand, then that's when you bring in the "fast acting" liquid chlorine for a quick raise.
