An SWG system IS a chlorine system it just makes the chlorine from salt water in the tub
What about this?--
1. It still needs chemicals…just not how you imagine
Both pool types need equal attention to the other factors, which make up swimming pool (or hot tub) chemical water balance. But, there may be some trade-offs.
For instance, a pool using solid chlorine, i.e. jumbo tablets or chlorine sticks may find that the pH (acidity) remains fairly stable, while a SWG pool more than likely finds that the demand of the pool for acid (i.e. reducing pH) is greater.
Also, a SWG pool will require more frequent additions of chlorine conditioner, as the chlorine your system is generating does not contain the chlorine conditioner.
2 “No need for maintenance” is a myth
A pool using a solid form of chlorine may occasionally require a “shock” to boost or super-chlorinate your pool, removing organic contaminants. A SWG typically has a built-in feature, which allows the SWG to perform a “super-chlorinate or “boost” function. A SWG system does require maintenance at times, including a process to remove scale, which may build up on the cells. The lifespan of a SWG cell is approximately 3-5 years.
Your pool may also require a topping-off of the salt level due to splash out, walkout or dilution from evaporation.
Sjde... don't over think this whole thing. Been doing the hot tub thing for 30 years.
I use one of these http://www.hydropool.com/cgi-bin/hy...HBCGBkj5_BfROsOieWknUF_Qxo5n9b0EMxhoCVK_w_wcB
Along with a couple 1 inch chlorine tabs each week and a tablespoon of non chlorine shock after every use (which for us is daily) that's about all you need, change the water every 4-6 months and adjust for PH (I have to use PH up) and you are good to go. My tub is always pristine! Test strips work great and stupid easy to use.
AO, we do not recommend the nature 2 for anything, it adds minerals and metals to water that can and will cause staining.. yes in a hot tub it is less likely it will be a problem if you drain 3 to 4 times a year but it's something you really don't want in your tub... and the reason you are adding ph up (you can use borax way cheaper) is because your 1 inch tabs are very acidic and also adding CYA with each one.
Update, seems nature 2 uses silver in the spa stick and that is better than the copper in the pool sticks but it is still a metal just wanted to clarify that
