2 speed motor runs on low speed turn it to high speed and runs for 3 seconds and shuts down can not get it to run on high speed for more than 3 seconds
Are you in Oregon or Spain? Edit your profile to add your state or country to your location so it shows up over there <-----, climate is important when we are helping you with your pool. Tell us more about your pool and equipment by adding the info to your signature, more here, Pool School - Read This Before You Post
Is it new?
Has it ever worked properly?
Shut down? Kicked breaker? Thermal shut off? Is it hot?
It runs fine on low?
What is the filter pressure when clean? And now?
Any bearing noise?
Is it hot when running on low?
