If you haven't added the CYA the test will still read zero. Once you add the CYA don't retest for a week, it can take 5-7 days to fully dissolve and read on the tests.
You can put the CYA in a sock and set it in the skimmer, leaving the pump running for 12-24 hours so it can dissolve. You can also hang the sock in front of a return. If you put it in the skimmer, don't backwash for a week or you wash out the CYA. Retest in about 5 days, but after 48 hours assume that the CYA is in the water and boost the FC according to the chart.
Remember to use the calculator to figure out how much to add.
Hope this helps
Hope this helps
