Not sure on the cost as the original frame I made up about twenty years ago and was a combo sled\wind shelter for ice fishing.
But figure about 3-4 sheets of plywood, the sides can be made with 2 x4 or 2 x 6 on edge instead of the 2 x 2 reinforced plywood I used. The pipe costs about 30$ per 100 feet, I am going to switch to 1/2" pipe this year as you can get smaller radius corners and cover more of the enclosure.
I have tried three different methods of running the pipe in the enclosure, single series loop, 3 seperate series loops and a reverse return system with 5 loops. I will be setting it up with the reverse return system this year, as that seemed to work the best.
I have used old intex pumps to run the circ for the solar, eventually switched it out to a dedicated 3\4 hp pump that runs when the regular 1 hp isn't running and I desire heat. In the beginning I just used a regular outdoor timer to set my run time on solar for when the sun was on the panels, if you circ with no sun or at night the solar collector will work like a chiller.
A few years ago I found an old heat\cool thermostat so hooked that up in the collector in series with a 24 volt transformer and an underground sprinkler valve so now the supply to the panel is controlled by the temp of the collector, with a bit of playing with it it nows only allows water through the collector when there is heat to be collected.
I did start out with a pallet covered in plywood painted black about 8 years ago, similiar to one of those bubbles, it worked but not very good.
The rule of thumb is surface area of collector should equal surface area of pool. Best I have done is close to 50% of surface area with my collector, which worked pretty good on my 16 foot pool, but like I said once I went up to a 24 foot pool it became less good then before, as I only had 90 sq ft to heat 450 sq ft of pool (24), whereas before I had 90 sq ft to heat ~ 200 sq ft of pool. (16)
