- Feb 19, 2012
- 78
I was looking at the FAS-DPD only Taylor kit. Two choices were available—1515 A & C. Below is what the company emailed me. The A kit is too small at around 18 test... so I added 2 oz for the 2 reagents. Should be here in a week or two.
Your email was forwarded to me for an answer.
The K-1515-A uses a 22 mL bottle. There are approximately 550 drops in that size bottle.
The K-1515-C uses a 60 mL bottle. There are approximately 1500 drops in that size bottle.
The number of tests from each size is solely dependent on the free chlorine and combined chlorine levels in the sample.
If we use your 6 ppm value then it would use 30 drops of R-0871-A (30 x 0.2 = 6.0); 550/30=18.33 tests at 6 ppm FC with a 22 mL bottle.
If we use your 6 ppm value then it would use 30 drops of R-0871-C (30 x 0.2 = 6.0). 1500/30=50 tests at 6 ppm FC with a 60 mL bottle.
