OK gang wrapping this post up.
Got busy after the remodel and sort of left things hanging here.
About one year out from the remodel.
Apologizes to all the late PM questions responses.
Here is a rundown of the common questions and hopefully this can provide a reference to others considering similar choices.
1. What color of BeadCrete did you use?
Majestic. This was from a PebbleTech authorized installer.
Not as common of a selection because I think people are a bit worried about it reading too dark.
If u are in the SE and SW with lots of sun, it is really a great unique choice.
Here is a representative photo of what the average color looks like:
2. Is the BeadCrete worth it? Does it really sparkle?
It is pricey so some of that depends on the budget. No durability issues after one year of use.
If I had to pick between an upgraded pool finish and better accent tile, I think glass accent tile (see below) gives more impact.
The sparkle effect is most pronounced in the deeper areas and needs high intensity overhead sun but it is quite dramatic in person:
3. Is the Lightstream Blue Steel tile worth it?
YES. It is also quite pricey but with sun and the polarized nature of the glass, it looks awesome.
When ordering please note the difference between square and linear feet.
I ended up with too much tile because that was not made clear (PM if in NW FL and need some as I have quite a bit left over)
Also realize the tile only lights up with sun and at certain angles; here are a couple of examples:
Sun but slightly off angle so tile is mainly blue; the BeadCrete shimmer effect here is prominent here.
Sun at different angles and different times of the day; very dramatic glow...
4. Did you ever get the pool lights to work?
Yes. Recently, however, they finally bit the dust.
These are Hayward ColorLogic 2.0 lights so an older model.
These had previously been replaced under warranty before.
There seems to be reliability issues with this lighting system.
I may not purchase again.
5. Are the tile pool steps slippery?
No. I talked to Lightstream about this and they have a subtle grain that gives enough traction especially after grouted.
Thanks for all the interest and I wish all a successful remodel to all.
Sayonara...
